Two Speed Booster
Hi, I’ve a problem with Speed Booster Plugin. In my Plugin page, I’ve two SB
Two Speed Booster Plugin in my WP
If I wanted to delete the old plugin ( 3.2 ), WordPress also clears the new plugin (4.0)
If I want to delete the old plugin (3.2), wp also clears the new (4.0)
How can I fix ?
Best Regards
You need to delete one.
Whenever you update plugins, you need to DELETE the old version from server, not over-write the old folder; and upload the NEW version.
I would probably delete both of those and install only the new version to be safe 🙂
Or, delete the 3.2 version.
Chris, I know that you have to delete a plugin before being updated. Turns off and then clears.
Thanks anyway to have it remembered.
The problem is that I did it, but they continue to be two. If I try to delete one, in the confirmation of wp I find two to be eliminated.
I can not understand where the problem is.
Okay, Okay… In the new update released theme Newsmag (1.6), Speed Booster Plugin, has two files:
Finally - The tiredness plays a bad joke.
Here’s the problem: td-speed-booster-old.php.
Thanks anyway.
Best Regards.
strange, i have installed the speed booster which i did not use in previuos version tho. it came up with two plugins as well as with files within so i have delted the old version. it working fine, but strange thing happening .. when you click on post or seomthing then wehn refresing the page it comes up with these colours and strctures sucg as grid etx.. vizu link
http://screencast.com/t/lgpxcnCG
however colours and grid are saet differently..
as it is
http://screencast.com/t/KGgeVrRpEi
do yu know what might be causing this or what shall i do?
We are sorry about this, the second file was added by mistake. We have this on our issue list and will fix this next week.
Until then you can use the 3.2 version of the plugin.
Sorry for the inconvenience!
I’ll be the first to admit I need to actually DO the update prior to answering some questions ’round these parts. 🙂
its trange i have tried to reinstal the theme , ihave tried previos version of the speed plugin, but its still doing the colouring thing.. can someone explain what i ma doing wrong.. please try to go post by post and see how it changing the colours.. http://www.electropiknik.cz thx
jan
ok is definately the speed booster coasing those colouring after refresh, had to remove the plugin and reinsall the theme with new files and now its alri..
