Typography changes in detail to posts – how?
I am using the Newspaper theme, but I never seem to understand how typography is modified in specific posts. The tagdiv composer alternative it also only available when editing pages, not posts. Is that how it´s suppose to be?
So, I understood the tagDiv Composer is not available on the posts, right?
To have the tagDiv Composer in posts, you need to use a Single Post Template from tagDiv Cloud Library and after you can change the fonts => https://www.youtube.com/watch?v=jQvA64uTLkI
if you use single template from Theme Panle, then you can change the fonts from Thme Panel -> Theme Fonts -> https://i.imgur.com/o3NhguE.png
