Hello team,
I have the latest version of Newspaper installed. I’m configuring the font, but the changes don’t apply.
What am I doing wrong?
https://fotos.subefotos.com/7c17a3ce54bd8c248343bff35cb98a04o.jpg
I have checked your website and I saw that you are using the Catamaran as font family with 300 value as font weight. Try to enable this value from here -> https://www.screencast.com/t/69LgtRGsE1, clear all the caches, purge CDN files and check the results.
Hi Catalin,
Thanks for reply. Yes, I have activated the options I want to use. I have emptied the cache of the web plugin. I opened an incognito window (anonymous) and nothing, the problem persists.
I don’t use cdn, I only use cloudflare as a DNS provider. The cnd is disabled (it always has been). PC test:
https://fotos.subefotos.com/cdc8a1c8b661adbfd8573ed59c44e37co.jpg
What could be the mistake?
Thanks, Jose
I’ve installed an extra to Chrome, which identifies the sources. And the result is this:
https://fotos.subefotos.com/8ab24f0ae447eea0455254ef231e2dd2o.jpg
I think it’s a real problem, no caché problem
I was struggling to find paragraphs in the post content, then I realized that the paragraphs in post have a white color for some reason – http://prntscr.com/nxcf0l There is some CSS that makes them white.
Regarding the fonts, from what I can see Google fonts could be disabled. Maybe you disabled them in the theme panel – http://prntscr.com/nxcgbd
The catamaran font is not loaded anywhere in the source page at the moment, so the CSS that should apply it won’t do anything.
