We just start to use Newspaper Theme to creat a merbership website.
To control memberships we use Ultimate Membership Pro plugin and it works fine so far. But now we discovered that Register form is unable to submit when tagDiv Composer plugin is actived.
Can you help us how to fix that?
Maybe there is a conflict between the composer and the plugin. Does it happen if only the theme plugins and the membership plugin are active?
The composer has to be active at all times after the latest theme updates, as most of the theme files are now located in it.
We haven’t made any testing with the theme or theme plugins and any membership plugin unfortunately. So I can’t say what the problem would be in this case. Conflicts may happen, not all plugins work with all other plugins or themes.
