Unable to add to posts (posts) Newsletter
Hello! How to display posts in the Newsletter.
That is, the Newsletter can be added only to the pages, via Composer, and I need in the posts (in the right column of the site).
I didn’t find the newsletter widget.
You can use the cloud library plugin to create a custom template for your posts and create the sidebar directly in that template using the tagdiv composer. You can add the newsletter widget to your pots and all other templates this way.
It would be nice if you created a widget for the Newsletter, which could be easily added to the sidebar. Don’t you plan to do that?
The method of adding a Newsletter that you wrote is not suitable for my site.
Unfortunately I think that there will be no widget for the Newsletter because this can be achieve using the custom html element.
If you want to set it in sidebar post you can set the code for Newsletter in a custom html https://www.screencast.com/t/L1gXiWkp7n3n
or you can set a single post template from tagdiv Cloud Library, edit the template with tagDiv Composer
-> https://www.screencast.com/t/8jLnhZT5
-> https://www.screencast.com/t/jdwF99utfjHS
Please tell me where to find the HTML code of the Newsletter, in order to be able to insert it in the custom html element?
I think I did not express very well, you can set in a html
-> https://www.screencast.com/t/L1gXiWkp7n3n
the code that you need to set in Newsletter, for example the code for Mailchimp; the Newsletter is just element that can be set with tagDiv Composer and this show only the required fields.
Thanks for help! The problem is solved.
