Unable to Customize Using Composer, Style for Description Text
Link to my site:
https://impactmagazine.ca/sweat-across-canada/
Some of the text I’m trying to modify includes: “Hooked after joining his first group fitness class, Andrew was encouraged to become an instructor.”
I’m trying to increase the size of the ‘description text’ size using the Composer/Style.
Unfortunately, none of my modifications are being previewed or saved.
If I type a new size, change the text colour, nothing happens.
Using the Composer/Style I am able to edit the ‘Title Style’ and ‘Button Style’; I am able to change the colour and size of that text.
However, I’m still not able to change the size of the ‘General Style’ description text.
Any help would be appreciated.
I’m still a relative newcomer to WP in general, and the Newspaper Theme.
What element do you use? If you have text with image, you can change the style of description, edit with tagDiv Composer, select the element and in the tab Style you can set the style => https://www.screencast.com/t/e4shhseo8
Issue remains unresolved.
I do appreciate the attempted solution, thanks Anamaria.
Yes, the element is a ‘Text with image’.
Your solution is what I was trying yesterday, and it should work, but doesn’t.
When I go to Style, and edit any ‘General Style’ option (font size, line height, etc…) in ‘Description text’, nothing previews and nothing saves.
Note: my ultimate goal is to change the font size of description text.
When I go to Style, I am able to edit both the ‘Title Style’ and ‘Button Style’.
Any additional help would be appreciated.
I went to WP / Newspaper / Theme Panel / Theme Fonts
I updated the size of ‘BODY – GENERAL FONT’ to 16pt, which also adjusted the size of the ‘Text with image’ description text to 16pt.
So, it looks like the Theme wouldn’t allow me to apply overrides on the ‘Text with image’ using the tag Div composer.
Makes sense that I couldn’t override the Theme settings, and I’m kinda okay with that.
Cheers!
That’s weird because the settings made with tagDiv Composer should apply. Please do a test using only tagDiv plugins on a staging website, because there is a possibility, to be a plugin conflict, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again. See if the problem persists.
