Underline color
hello
I installed a template demo having the underline yellow color on mouse over, I am trying to turn yellow into green but I do not know to do it
here is the site link https://lombardianotizieonline.it/
(in case it will be required to enter e pwd, you can use “Braintech.2019”
thanks
Hello !
That can be changed by going into Theme Panel – Theme Colors – General theme colors: https://www.screencast.com/t/7cE220nl
Actually I had already applied that change, but no success in my objective
The yellow underline is still there when you go with the mouse over a preview title in the home
tks
Hello !
Please clear your cache. As you can see here it works fine on our side: https://www.screencast.com/t/0I6RQuA8
yes, but let’s go over the preview title below, that is “Spaccio droga, De Corato: è emergenza in diversi boschi e parchi lombardi”, you will see a yellow underline
Hello !
That can be edited by using the tagDiv Composer on those blocks and you will see the hover color as you can see here: https://www.screencast.com/t/qhajoPvH7PK
