Undo does not work in tagdiv
ctrl + z neither ctrl + shift + z work, nothing gets undone in tagdiv at all.
To add the undo, redo button, you need to activate the theme from the Manager panel – https://i.imgur.com/5um4NOE.jpeg – https://i.imgur.com/aT7mAeh.png, enable the settings, and save the settings.
Also, the undo/redo can be used only as long as you are on tagDiv Composer on that page or template, if you exit and open again the page/template, the undo redo will not work until a new history is created.
Hi. Could you please provide a little more step-by-step detail about how to enable the undo/redo options when editing? I cannot find a way to undo a change and can’t figure out how to activate the undo/redo options. Thank you!
Hi heyjohnboy,
The option for undo and redo can be enabled from tagDiv Composer > Manager > Settings https://i.imgur.com/kATrLqT.jpeg https://i.imgur.com/LjZwDDx.png
https://forum.tagdiv.com/tagdiv-composer-website-manager/ Those options will work only as long the page with tagDiv Composer is opened, after you close it and open it again a new session for undo/redo will start. In this situation, you need to use a page/remplate revision
