The unique article setting is not working on our front page. It used to function correctly, but is not working now.
I’m not sure if this is update related or a feature on the page (like youtube playlist) or from VC element conflict.
When I save the page as “Enabled” the setting is reset to “-disabled-” when it reloads.
Website: http://bit.ly/1AOikBD
Thank you! Great theme, love the features, use it for our 20k/month site.
Update: It looks like the setting has to be set and saved each time the page is edited. It looks like the setting doesn’t lock in as enabled. So, each subsequent edit/save to the page “breaks” the unique article feature.
Is that designed behavior?
I also checked this and did not found any issue with unique articles, I couldn’t recreate this. If it is enabled every time you edit the page it should remain enable. Please check this also without any plugins active leave just Visual Composer active, clear cache and see if you still have this issue.
