Unique Article System Queries
I saw a feature on the V3 update. It says that the Unique Article System will not show one post many times. But on my site it is not working? Is there anyway to enable it or I need to do something else?
To activate the unique article system, edit you homepage and enable it from there. Now you should have no duplicate post on the entire page.
