Unique Articles and Pagination
Hello everybody,
is there any option like CSS or some other customized code that can prevent doubled posts for pagination when we do not want to or can use the Offset-Function? The Unique Article Function does not seem to work.
Thanks a lot in advance,
Karen
Please check our documentation from here: https://forum.tagdiv.com/unique-articles/ or you can use an offset if you use a cloud template and not a default one.
Thanks for your response! I’ve already checked the documentation. The question is whether there is a customized option to prevent doubled articles with pagination other than the offset function. Some kind of CSS or plugin or something else?
Unfortunately, we do not have a tested plugin or a CSS to achieve this.
Thank you for understanding!
