Hello vdaatland,
Until now, we do not have any bad reports in this regard. Also, please keep in mind that the unique articles do not depend on whether or not you are logged. Try to make a new clean install from scratch with the latest version of the theme, clear all your caches, purge CDN files and install only the plugins that come bundled with the theme and rule out any conflicting plugins.
Hi!
Thanks for quick reply. After bughunting it seems to be in conflict with Ultimate Membership Pro-plugin (https://codecanyon.net/item/ultimate-membership-pro-wordpress-plugin/12159253). Unique articles stops working for non-logged in users. Why I don’t know. We’ve deactivated it and now it works as it should.
I’ll make a support-ticket with the plugin-developers. It’s a popular plugin we want to use for membership-fees, so it’s kind of a big deal to get it working.
I’ll update you when we find a solution!
vdaatland.
Glad you have managed to solve this. Note that we didn’t tested the theme with Ultimate Membership Pro-plugin and we can’t guarantee that it will work fine with it. Maybe plugin’s developer may be able to provide a hint but you may need some customization to make the plugin compatible with our theme.
Hi!
No, we went for armember-plugin instead
https://codecanyon.net/item/armember-complete-wordpress-membership-system/17785056
Works fine there.
Regards,
Vidar
