Unique designs for posts (no template)?
Is it possible to design some individual posts without imposing a template? In divi I was able to create post designs for some posts that were unique to that post (without affecting header, footer or sidebar) but when I try with Newspaper I end up changing the single post template for every post.
I want to use posts, not pages.
If you want a different design for some posts, you need to duplicate the single post template or import a new one, customize it as you want, and after from here, you can assign it individually for each post -> https://i.imgur.com/e1R1b83.png
