I have several insecure links (http:) and I have found these links in the database. It is an image that comes with the original Template and that this always loads in the design. I have modified in the DB, changing the HTTP: by HTTPS: but then the web page does not work. I get an error that says: debug wordpress. but nothing comes out except this text.
the photos are repeated in this table:
http:/www.website.com/wp-content/uploads/2020/08/hero-bg.jpg
How can I remove these unencrypted links or modify them?
  • This topic was modified 6 years by newsuseri.
Hi newsuseri, is not a very good idea to make these changes in database, it will be batter to use a ssl plugin like this one -> https://wordpress.org/plugins/really-simple-ssl/
Also what you can do is to regenerate the images or to change the image hero-bg.jpg from the place where is set.
Thank you. The solution with simple ssl works.
Hi, I’m glad that I was able to help!
If you have other questions, just let us know!
Have a nice day!
