Please view with mobile browser, especially OPERA MINI for android.
PROBLEM:
There is an unexpected semi-transparent black layer over homepage, if i click on any posts the result is same.
I tried to solve by activating Newspaper mobile plugin but no difference.
Please help me to solve this problem.
The menu buttons are also inactive.
the homepage is not loading all. a message of wp booster error appears after latest articles.
hope this will be fixed soon. meanwhile I will try to upload the old mobile plugin.
regards,
http://www.midronepro.com
Hy mystudent,
Please notice that the Opera Mini browser is not tested with our theme and we cannot make for sure if the theme will work as properly with it, sorry! The all browsers which are fully tested with our product, you should find here -> http://screencast.com/t/MSqrDf62slre
Hello mystudent,
Where do you see the OPERA MINI to my screenshot? Please notice that only the OPERA browser is tested with the theme and not the OPERA MINI. Please notice that these are two different browsers. I have checked your website in the Chrome and seems to work as properly. Please provide some screenshots where you explain the error.
I have exactly the same problem, I had not noticed this before but then when I activate the mobile plugin, my posts are not clickable.
I am losing a lot of traffic and this explains the high bounce rate I have been experiencing. A huge percentage of my visitors are on mobile and if this is not resolved. I have to switch to another theme.
Exactly, more than 75% visitors come from OPERA MINI browser and this is a serious issue.
I checked many themes and they worked perfectly fine with OPERA MINI but not this theme.
I am in mood to change my theme now and discontinue with Newspaper theme although i love this theme.
Hello mystudent,
Unfortunately, the OPERA MINI is not tested with the theme, sorry! I have added this suggestion to our list of fixes, in a future update, it is possible to include the Opera Mini to our supported browsers list, but we cannot say for sure if it will get done in the next update because we have a big list of fixes, improvements, and suggestions to implement. It’s hard to filter them and select which one gets implemented now and which one gets postponed. The developers decide if it gets done or not, though.
