update 1.5 problem (How to make the shift of SQL)
What I need to do exactly, since it is not clear to me
https://forum.tagdiv.com/update-newsmag-to-1-5/
Currently these errors are displayed when upgrading
[td_slide limit=”5″ custom_title=”Latest Post” td_filter_default_txt=”All”]
[td_ad_box spot_id=”sidebar”]
These are the errors that I have seen for now
Hi ma using childtheme and after update via ftp replacing the theme files my entire website crashed down in to white screen, i decided to move back but it will not work either ,, iam kida stuck now://// http://www.electropiknik.cz
its going to the loop, i figure out what the issue us. But?? i am sugin childtheme new update reguires install js_composer plugin.. but it wont let me do it as it can not be installed from the admin sayi.. /home/domeny/electropiknik.cz/web/subdomeny/www/wp-content/themes/newsmag-child/includes/plugins/js_composer.zip it can not locate the plugin from there.. so switched back to nesmag theme and it will install it but then the entire web crashes…
well ok, i have raplaced all the files with the updated version, before that i have removed js_composer plugin. after the update i have tried to update actually install the updated version of visual composer. it will let me install it but when i activate the plugin the entire web crashes…
Sir @jan-klobusnik, please do not write spam, visual composer if upgrade is very simple, just unzip the ZIP “js_composer” and upload it via ftp!
if you need more help, open your new post!
please help how to write the data to SQL and fix errors
I suspect that in the child theme you changed some of the files that were updated in v.1.5
You have to also update those files in the child theme and add the custom modifications again.
Also make sure you updated the plugins. The shortcodes shouldn’t be a problem, they will just appear on page as a code, you have to locate them and manually modify them to the new format or use the SQL query (in phpmyadmin) to automatically replace them in the database – http://screencast.com/t/G1SwZNDb
Thank you, Emil G.
