First the new update will not work. Previous uploads, updates, plugins all work. Even tried changing directory permissions to 777 still same error.
Updating Theme Newspaper (1/1)
Downloading update from https://cloud.tagdiv.com/wp-content/uploads/2022/05/Newspaper.zip…
Unpacking the update…
An error occurred while updating Newspaper: Could not create directory.
Also my posts are not displaying the featured images in the thumbnail and also the main bigger image. upon looking at the media folder i see a ton of images like 16x different sized and cropped images for each one image thats being downloaded to media. Upon viewing the blank image holder it shows an error message as the actual image. The site in question is BitSwapNow.com
Welp im a fool and found the issue it was the quota size on the server was maxed out lol i never set it to more then 1gb smh thanks anyways haha
Actually that was not it. I think its an issue with the newspaper Crypto Pro themes multiple image sizes its using and im using OctoLooks Scraper to download images from other websites to my media and then use and embed. Im seeing like 16 different photo sizes in the media folder but a lot are blank and throw up some error when trying to view the image and on the webpage is a blank or grey holder where said image should be. Any help is much appreciated.
Yes it seems to be aggregating fine now. Thank you Bettina!
