Updated to 4.9.6 from 2.3.6 and article images missing on home page
http://www.dawgtime.com
Article images missing on home page, many of the drop down menus missing as well.. Should look like bamatime.com
Hi gkprokay, first please make sure that you do not have a plugin conflict, please disable all plugins except tagDiv plugins and if you are using a child theme, set the main theme and see if the problem persist.
Let me know the results!
Hi Calin, thanks for the tips. WPBakery Visual Composer and Revolution Slider plug-ins seemed to be the culprit. However, the images are back on the home page but now other items are missing and seeing text? Any other suggestions? What do you mean by “if you are using a child theme, set the main theme”? Can you send me images or describe how to do this? Thanks, g
About WPBakery Visual Composer and Revolution Slider plugins, make sure that you have them updated with the new versions from package 4.9.6 then it should work properly.
If you do not know about child theme, most probably you are not using. For more details about child theme you can check our guide from here https://forum.tagdiv.com/the-child-theme-support-tutorial/
