I installed the 8.5.1 update and noticed that there was an error on the mobile display. I manually installed the plugins included in the zip file and now everything is fine. I couldn’t find anywhere that the plugins were updated, but I think this was the case. If it is so and not some other problems that magically solved itself, you may advice on what plugins to reupload. I am saying this just in case other users have the same problem.
This topic was modified 8 years by
beppepicaro.
Hello my problem fits perfectly to the headline of this topic, so I hope you’re not angry beppepicaro, if Im using your place to describe my issue.
Yesterday Ive updated my theme to 8.5.1 and its running fine except one thing.
The mobile layout has shrunken a little bit and it doesn’t look as good as before:
How can I fix it to the previous look?
I haven’t noticed that on my side, but I am still “offline” with mine. Anyway did you reinstall all the plugins? Maybe “they” forgot to instruct us to update those as well. Or maybe you made some changes to the css file?
I have updated the whole theme manually, by deleting the old theme and uploading the new one. I did the same thing with js_composer, td-social-counter and td-speed-booster. And of course I haven’t changed any css code.
@fenomeno0chris
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
