I just installed your theme on my website: http://www.enterao.com, and I have a serious problem, the website is constantly put in blank, for a long time. Need urgent help with this, because I’m losing customers and money.
I read here on the support page I had to change several parameters and so I did, I changed:
memory_limit = 256MB
post_max_size = 256MB
php upload_max_filesize = 256MB
Thank you very much
Regards,
You may want to switch to one of the default themes like twenty-twelve temporarily, and then try turning off all the plugins you’re using. Also check your htaccess file to see if anything is in there that shouldn’t be. Also turn off or disable the “beta” speed booster plugin with the theme as that is only for advanced users willing to test “edge” applications. Not sure if this helps you or not – but I’ve been able to just switch theme to TwentyTwelve when I have bizarro issues, to at least keep the site live!
The problem was with WP Super Cache plugin. Via FTP, I deleted the folder of the plugin, and problem solved. But now, I don’t have Cache Plugin. What plugin for cache, you suggest me?
