helo my site is http://nusantaran.com/
menu not work, can you help me.
thanks
I’ve checked your site and the problem seams to be related with the css code which apply only on home over the sub-menu item. Try to deactivate all plugins except Visual Composer, clear all caches also disable any minify options for css/js if you’re using, clear all caches and test again.
Let me now how it goes.
