SLOW LOADING theme panel
I didn’t do a backup because the demonstraton in the video didn’t work.
I thought I was updating my theme up until now, but I noticed that I never updated my theme correctly using FileZilla – (my version of theme up until a few minutes ago) Theme name: Newspaper Version: 1.7.1
After I uploaded the newer version the new theme panel loads FOREVER
literally a few minutes (around 3 minutes before I can do anything)
Why?
  • This topic was modified 12 years by Marija1m1.
the problem resolved itself..
*update…
when I load the theme panel for the first time is always takes up to three minutes to “load” before I can use it.
Is this normal?
Also
Can I feature two more articles on the front page under “latest articles”
hi,
is not normal to take 3 minutes, what plugin do you have, disable all an try again.
to find out if the theme has problem, you need to instal it on your computer and install the demo data (no plugins). If it duos the same on your computer then there is a problem with the theme, if it doesn’t then the problem is from somewhere else.
Latest article
you have 2 option
either use a template: http://screencast.com/t/67DIv5ksAWv
or from blocks : http://screencast.com/t/UE2m8Sbj2Hg
http://screencast.com/t/89G2ri3BNR
http://screencast.com/t/YQ45UTzY
Thanks for you message.
Radu A.
I disabled all my plugins and the same thing happens my screen freezes and it keeps loading the panel for about 3 minutes
How do I do this?
“to find out if the theme has problem, you need to instal it on your computer and install the demo data (no plugins).”
  • This reply was modified 12 years by Marija1m1.
hi,
well, do a clean install on your computer, download XAMMP (this is a package that contanins Apache web server, Mysql, and some other software), download wordpress and run the wordpress instalation steps then install our theme. After this install the demo data:http://screencast.com/t/pDt1WbSw6 .
at this point check how fast the theme panel is loading.
if is slow then there is a with the theme.
if is fast then the problem is from somewhere else (plugins, or configuration that the hosting company has for that server).
from my experience I can tell you that there is a javascript file that belongs to a plugin that takes to much time to load, and our panel wait for it to load.
however finding this file and stooping it is no easy task since everything in working in the hidden from your eyes.
Radu A.
This may or may be related:
General note, some Java based stuff works better on Chrome than IE, and some java stuff sucks on Firefox. Many folks forget to check what plugins they may have running inside their web browser and which also use java … this is why Chrome and Firefox are starting to quash many of the plugins/add-ons for browsers. This is something to check also and possibly deactivate any Adobe, social media, custom menu bar, or other stuff installed as an “addon” to the actual web browser.
This drove me nuts with my ecom solution last year and my syndication module in WordPress; switched to different browser worked right, went back to orig and turned off all the stupid add-ins for browser I had at the time. Cleared my cache completely, added a little more disk space to browser cache default size. Really helped.
Your mileage may vary.
@Marija1m1
if you still have issue, can you give us access to your WP to take a look? Send access via email at contact@tagdiv.com write in title message FOR MARIUS and paste a link from this conversation.
Marisu I am sending you an email.
I tried to update my theme but it doesn’t show that it update from 3.2 to 3.5
it freezes up and now crashes my site.
I have also now installed that automatic update plugin and I am not sure what is suppose to happen but when I pressed the automatic update it just was “buffing” for a while I’m still waiting for it to stop buffing.
Is it possible that I installed the theme twice? via filezilla?
I sent you an email
We will check the email.
