URGENT: Images Not Appearing in Post
I hope someone can help me. I have added images to a post and they are not appearing. Please see link: http://www.crushfitnessmag.com/10-life-lessons-black-panther-movie/
From what I can see none of the images in the post content are found on your server
– https://www.screencast.com/t/RrcL4gdXFtlD
Maybe there were problems uploading them to the media library, check if they are present in the library.
They are present in the media library. How do we add them to the server?
The media library is located in the WordPress install, and WordPress is located on the server (by default), so other then uploading the images there are no steps to take before using them
– http://www.wpbeginner.com/beginners-guide/where-does-wordpress-store-images-on-your-site/
Try re-saving the permalinks in WordPress settings. Also contact your hosting provider and ask why images from the media library are providing 404 errors. They should be able to check that for you.
I spoke with GoDaddy yesterday and was told that it is a theme issue and not a hosting issue.
Resaving the permalinks didn’t work. I sent an email with my user login. Can someone please look around?
We will take a look if you have sent us an email with admin login details.
Hi Simion,
I have the same issue, and even I reviewed my server and I found there all the images I tried to upload to the Media Library.
What can I do if my web hosting is doing well?
Regards
@Equinoctial
So the problem is that images you uploaded in the media library cannot be used on posts as mentioned above.
Try if possible as a quick test to deactivate all your other plugins and check if this solves the issue. Check if possible with a default WordPress theme as well. Let us know.
