Hi there,
I need some help fast. My mobile menu when pressed, creates a pop-up window (very strange).
Am I missing something in the setting?
Ken
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also please provide a link to your website in order to inspect.
Hi Vlad,
Thanks so much for your super fast response.
I’ve tried that but no change.
Here’s the website:
Thank you for your help so far!
From what I can see on your website, you have set an image as background for mobile menu and this is not load -> http://prntscr.com/p5ikci what you can do is to go in Theme Panel> Backgrounds and replace these images -> https://www.screencast.com/t/FFPTEDul also please check the color for menu and search on mobile, now yours is set on transparent, you need to go in Theme panel>Theme Colors and set here some background colors -> http://prntscr.com/p5ilio
If there is still a problem, just let us know!
Hope this will help you!
So if I understand correctly you want to change the hamburger icon menu http://prntscr.com/p5ozmd if is so then you need to use a header template from cloud http://prntscr.com/p5p09u , edit the header that you are using and do this steeps -> http://prntscr.com/p5p0jq -> http://prntscr.com/p5p0v6 -> http://prntscr.com/p5p18d
Hope that this is what you need to achieve!
So if you are using only the Facebook and LinkedIn social, then you can remove the “#” from the rest of social networks from Theme panel>Social Networks http://prntscr.com/p6qxaf -> http://prntscr.com/p6qx57 once that the field is empty the icons for those social will be remove.
