URGENT ,,My Theme keep generating Span posts ! Help !
My theme is generating spam posts, I deleted them and they keep being generated and published , at first i though it was a specific user hacked, so I deleted that user but now it generates posts without any author!
My url is libyaninvestment.com
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
If the problem is still there you can delete the theme and install it again, in this way if you have some code in them files this will be removed.
