I just notice pagination does not work! Please help us… there is another topic about it here and no answer from you guys. It’s pretty serious!
Do you guys intend to fix this theme issue when Facebook is active? Because it’s essential for me and possible for many others to use Facebook plugin. I can’t not get the results I have when Facebook plugin is active without it. Not even when posting my posts to my timeline. Also homepage theme is so slow and I have no idea why. I don’t have many active plugins that justify painfull load times.
Please do fix Facebook compatibility issues.
What plugin can I use for sure to add Facebook comments to my blog? Also any ideas on how to show share buttons on the loop?
I am so sad about my blog right now! I picked your theme after digging a lot and I thought I was on the right path but not being able to use the official Facebook plugin and not showing the share buttons on the loop is really costing me “likes” and “shares”. The layout is great and I was able to give my touch to it but it’s really you guys should know above all that Facebook and shares are the key to everything nowadays!
1. I’ve got some good news and some bad news… The good news: I’ve tested our latest version of the theme with the latest version of facebook plugin and it seems to work now. The comment box works as expected and the pagination also works as expected.
The bad news is that I don’t know who fixed what… either we changed something or they change something or wp 3.8 changed something.
Can you try with the latest plugin ? and if you have problems with pagination we need to figure out a way to update your site.
2. shares in loop… in a blog like page or where do you want them to appear?
I know some of our clients worked a lot on their sites… including you. We will try to assist you to make it work ok.
I’ve got the same problem on our ebike magazine: http://www.ebike-news.de. But there is no Facebook-Plugin installed.
Any idea how to fix this?
can I get wp-admin access? contact@tagdiv.com – please put a link to this thread in the email. Sorry for all the problems, we will help you asap.
@madox56 you site is http://www.ebike-news.de/
I found an email in spam folder.
I check you site please update to latest version of the theme. Also what you can do is to disable the plugins one by one and check if works, could be from a plugin conflict, i see that you have a lot of plugins installed.
Hi Marius,
We tried everything you have recommended so far – without any success. Even the update to the new version did not work out.
Other ideas: What do you think if we would only use the visual composer for the main page?
I know from some posts that Google loves the wordpress recent articles. Do you think that our page rank will be lowered then?
Best
@madox56 It looks like the themes html is compressed by some kind of plugin or mod_pagespeed. Can you disable mod_pagespeed or the page minifaction plugin that you are using?
Please let know if it works after disabling mod_pagespeed.
If you use the blank homepage + pagebuilde it will work also… for SEO I do not know how that will affect your rating but I think it will be better if we manage to sort this problem out for you. (I really like sites with pagination 🙂 and i think Google likes them too )
Just FYI to all when any site is running mod_pagespeed it’s really easy to tell as GPS will insert beacons or other things in the page HTML source to identify that.
eg
<script type='text/javascript'>window.mod_pagespeed_start = Number(new Date());</script>
<script pagespeed_no_defer="">
etc.
