Urgent Please Problem with Visual Composer
After updating the theme and Wp at 4.5 it is impossible to use in backend the visual composer.
The error in the js console is this one
Uncaught TypeError: $template.get is not a function
backend.min.js?ver=4.9:6 Uncaught TypeError: $template.get is not a function
WPBakery Visual Composer plugin version is 4.9
Help please
After WordPress updated at V 4.5 there appeared a jQuery conflict in our theme, also older version of VC won’t work with it. We fixed this conflict and the current theme version available on themeforest works fine, also we included last version of Visual Composer plugin.
Try to update the theme at current version available on themeforest, also update Visual Composer at V 4.11.2 following our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ deactivate all other plugins, clear all caches and test again.
I hope this helps.
