Urgent please! Web does not work after updating
Hello, I have transferred the files from the patch_9.5_9.6 folder to the theme folder in the FTP and now the webpage does not work.
The website is: https://www.discipuli.es/
What I can do? I need to fix it fast 🙁
I have done a restoration of the file backup and now it works, but we stay with the previous version.
This was the error he gave me when I replaced the files: https://i.imgur.com/Dp67HHh.png
How should I upgrade to the new version then?
Please make sure that you have download the theme with all files and documents.
Also please check our documentation for How to Update the Newspaper Theme for WordPress -> https://tagdiv.com/update-newspaper-theme/
Also please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
– https://tagdiv.com/newspaper-theme-requirements/
and please increase all requirements that are lower, and follow all steps
