Urgent problems with header and TD Composer
I’m not entirely sure how to explain this because it’s very strange. Suddenly, the TD Composer stopped working, and the header on my website disappeared. I can’t access the Composer as it just keeps loading. Initially, all templates were loading “post” regardless of whether it was a template for a page, and now it’s not loading anything at all. However, the URL in the Composer indicates that it’s trying to load a post.
Before the issue occurred, I hadn’t installed or updated anything. The problem appeared out of nowhere. I’ve now updated plugins and everything else, but there’s no change.
Theme version is 6.2 – should i update? (running child-theme).
View post on imgur.com
Update:
When I load an header template (from Cloud) the TD Composer for that header works, but still not for my old one. Still does not show up on homepage when i choose it for Global.
Still cant edit any other pages or templets either.
here is image of console:
To be clear, the two problems is:
1. The header does not show on my webpage (When TD Composer plugin is deactivated it works).
2. THe tagdiv Composer does not work at all.
Iv tried everything.
Deactivated child theme. Plugins etc etc.
I think that you have made some changes in the header template and this caused the issue.
You can try to revert an old revision on a page/template -> https://www.wpbeginner.com/beginners-guide/complete-guide-to-wordpress-post-revisions/
Also, you can contact us via email at contact@tagdiv.com and provide the wp-admin access. Include the link to this topic.
yes, I have done this on the places where I may have adjusted headers. But it could be on some of the removed pages/posts. What should I do in that case? Is there any way to change it back anyway?
I’ll set up an access for you.
Please contact us via email.
