USE 7 DAYS POST SORTING PROBLEM
Hi !
I use the option “7 days post sorting” and I think it doesn’t work because I have always the same posts on top. (they are the most view since the beginning of the site)
Should it not update all 7 days ?
Thanks a lot !
Antoine
http://www.weneedcafeine.com
  • This topic was modified 12 years by EliptiK.
This is because the view counts aren’t updated. We know about this issue and we are working on a better implementation for this.
You can disable cache plugin if you want accurate 7 days sorting or make the caching period shorter.
You need to use some additional plugins to make the views working with cache plugins.
Sorry about this!
Thanks for understanding!
