Use un-cropped images for post thumb-nails
Is there a way to just use a the featured image of a post and not the cropped thumbs?
So if we are listing a bunch of companies and there logos are the post feature image, would it be possible to display a featured image instead of the ones the theme creates.
Hello elpaulli,
Unfortunately, our theme does not have any option that allows you to disable the thumbs for Featured image, sorry! Our product uses this method to crop the image if it will be higher than default container and to fit the image as expected at the post content.
That is what I figured, but I had to ask. It works great for most everything else. Just a specific application here and there!
Thanks for all the great work your team does.
