User Reviews and Smart lists questions and suggestions.
I checked the “Reviews” functionality of the theme and I could not find a way to enable User ratings. If I missed it, please let me know how I can do it.
If I am correct and you can’t enable user reviews, then can you please consider this on your “to do next” list. Having a review function without the possibility of enabling customer’s review (not just authors/editors) it’s like having a gimped feature.
Also, can you please suggest me a compatible review plugin (with user reviews capability, of course) that i can install and works with your theme?
Last part of this topic is about smart lists.
What I’ve noticed is that, all templates available alter the structure of the posts. I think it would be very useful to add a much simpler template that will only “number” the Titles. In most cases a post has a “human logic” to it that dictates where goes where. All template alter this logic and display the information their own way.
For example: If I do tutorials, I have a H2 title about “something”. Next I describe/define that “something” and, in most cases, I exemplify my description/definition with a picture. It makes sense to have that picture AFTER my description/definition text message. Else, the post might be confusing when somebody sees an image that doesn’t make sense at first and than has to read about what that picture represents.
Most useful to me would be a simpler smart list template that only alters the Titles (by adding those nice numbers) and lets the author build his/her post the way he wants, the way he/she thinks it makes sense.
Or, if you want to take it to the next level, have other template(s) that alter only the titles but also add that slider (previous/next) functionality.
That’s it.
Waiting for your help and feedback on this topic.
Thanks in advance.
Unfortunately theme doesn’t have an option for users to add reviews, you will need to find and use a plugin for this, but I cannot make any recommendations as I did not tested any plugin like that, sorry! Thanks for suggestion I have added this on our list and we will think about this, however we have over 250 features on our list we have to pick very carefully what we implement.
That is how the smartlist was designed you can alter that behavior if you don’t like it or you hire freelancer to do it for you if you don’t have coding experience as we cannot provide any type of custom work at this time. If you want to add description above the image you can edit smart list style that you use and place the description above the image – http://screencast.com/t/NRoo40Ts – http://screencast.com/t/lMEfsxt2
Hope this helps!
It helps.
The ability to allow user reviews is the one big missing piece of functionality for me, it would be amazing to have this in a future release.
Is there anyway that TagDiv can share a roadmap and way for roadmap suggestions moving forward?
Graham
We understand, there are several other theme users that have requested this ability and we do have it on our requests list, however unfortunately a more accurate answer than this I can’t provide at the moment because we still need to review this possibilities of implementing this and methods that we may approach. We will get back with and update on this as soon as we have a decision on this. Until then you can try to find and use a plugin.
We don’t have a roadmap suggestions system setup at the moment but we may consider creating one as there are lots of feature requests and it’s getting very difficult to follow them.
