is there a possibility to use the visual composer and the post blocks also for posts?
We would like to show a list of posts of a certain category and tag below some posts.
Thank you
Klaus
There is a possibility by activating visual composer on posts from here: http://screencast.com/t/sDMHzvUr9 but visual composer is not tested on posts and could provide mixed results.
Thank you. I have tried that and Visual Composer itself is working properly, but the Newspaper blocks are not. There is only one block style showing (regardless of which block I choose) and custom post types are not working…
So we will have to write our own shortcakes to implement what we need…
