Hello
This is actually not so serious support but a minor help
We tried to use the theme with CMS Commander plugin
We did 3 demo installations that will correspond to
the cms commander that will post to all websites
directly the same post. Through CMS Commander
the post looked corrupted so we contacted with CMS Commander
about the issue. They responded :
Hi George,
after having a look and simply editing and saving the article (without any changes) in your site’s wp-admin area it is now displaying fine.
What that means is that your theme requires some additional setting for posts to display correctly. This would have to be set up when posting from CMS Commander, by using the custom field settings on the CMS Commander Editor page. You would need to contact your themes support team and ask for the custom field name and value that is required by the theme. They should be able to let you know what default setting the theme expects for the custom field that determines the page layout.
So we ask about the custom field name and value that is required by theme.
We appreciate your help and the excellent theme (owner of 4 licences)
I would help you, but I would have no idea how that plugin works unfortunately and what custom field would that be, or why the posts are corrupted with the plugin.
The theme is mainly designed to be used with posts created and published manually, the default way.
That will ensure they display properly and have the intended functionality. Posts from external sources or imported automatically from various places will most likely cause problems.
So the theme works in the conditions it is meant to work, up to this moment we have not made any tests for compatibility with the plugin you mention or any form of automatic posting.
Maybe there will be testing in the future, I am not aware of such plans however. There are many requests and more important priorities currently. Sorry for this inconvenience.
