Using "cooked Pro" with Newspaper Theme
Hey all,
I want to use the Cooked Pro recipe plugin with the theme. It seems to be perfectly compatible and shows the recipes correctly.
I want to be able to show a big grid with the latest recipes but tagdiv only seems to have options for regular posts.
Has anyone had any experience using cooked with tagdiv? Any suggestions on how I can use the shortcode for cooked to display recipes?
An example is that cooked creates its own category Ids and I would like to show latest posts from that category id (1675)
There isn’t a filter to show posts from that id?
Hi, unfortunately we do not tested the cooked Pro plugin with our theme, therefore we do not know if this will work or not with our theme.
Also using our blocks you have the possibility to display posts, page, event -> https://i.imgur.com/OBbb3cn.png -> https://forum.tagdiv.com/block-settings-guide/
Did you figure this out?
