Using DFP with Newsmag
I understand Newsmag does not offer native support for Google DFP. I would like, then, to manually insert the invocation code that goes inside the HEAD section and use the text widget to position the banners in different places. My questions are:
1. Is there anyway to include javascript in the HEAD section without touching the source files? Using the theme panel?
2. Is there anyway to avoid that the HTML module converts special characters into HTML entities?
1)Please notice that our theme does not have any such an option that allows you to change the header.php from theme panel, sorry!
2)Sorry, the theme does not have any such an option. If the strange characters appear, you need to consult this topic from here ->
https://forum.tagdiv.com/topic/strange-chinese-symbols-replaced-icons-and-arrows/
https://forum.tagdiv.com/topic/font-blocked-from-loading-by-cross-origin-resource-sharing-policy-no-access-co/
Hope this helps!
