Hello, on our website (https://staging.charterpartydisputes.com/), which is mainly going to be a blog webpage, we have set a page as the Posts page through Settings > Reading. The pagination on choosing how many posts are displayed on each page seems to be working right, although the excerpt options don’t work accordingly. We’d like for the posts to be displayed as excerpts, showing the first lines of each post when on the Posts page. Then the user by clicking on “Read More” can see the full post. Are there any options to control this behaviour?
For example, you can use a flex block 1 with those setting to achieve this: https://www.screencast.com/t/f8d1BLGIisJ
Please note that you need to use a cloud template for that page.
Hope that helps you!
I have to do this for every single post? No way to control something like that globally?
You can install many cloud post templates and you can see them in a list here when you access a post: https://www.screencast.com/t/9mY3SZgZn
In this case, Global means that the template it’s set up for all posts by default. But, for example, you can have a post with different template and without Global. This you can do by accessing the post you want to choose other template, select from the list the template you need, that’s all. You can see how they are looking by select other template for example. The settings will be different because it’s other template, but when you assign/select the global template again you will have the same settings and you won’t lose it.
So, every changes that you make in a global template it will display for all the posts you have assigned the global template.
Thank you for your response, I’ll check it out and let you know.
