Using Multiple Templates for Posts: Feasibility and Plugin Recommendations
Hello! We need to use different templates for posts. Is this possible, and if so, how can we implement it? Or perhaps you could recommend a plugin that’s compatible with the theme?
How can I create a template here that I can later select for individual posts, rather than importing it?
https://prnt.sc/_X9Qba0SF6x_
You should import a blank template and start customizing it with the tagdiv Composer.
I see that I can select a global template here, but how can I choose a separate template for an individual post while keeping the global template for the other posts?
https://prnt.sc/zF1pjSeYk1gI
You can assign the template like this individually: https://app.screencast.com/IkdnqYZvldjR7
Or you can set the correct template for your posts by category in the Newspaper -> Theme panel -> Categories.
