Using newspaper for ecommerce
I m using Newspaper for ecommerce. Although its not for ecommerce I love it!
İts fast, easy to set it up. And its very good for Seo. I hope you make some improvements for woocomerce in Newspaper theme.
İs it possible to put woocommerce sidebar for product filter, filter by categories e.t.c.?
If that possible I definetly buy more Newspaper themes for my new 2 websites.
The theme is indeed compatible with the woocommerce plugin. In the theme panel template settings you can set sidebars for woocommerce pages
– https://www.screencast.com/t/elgAaOns
The woocommerce widgets will appear once the sidebar is set for the woocommerce pages
– https://www.screencast.com/t/qX9vqQ9MF
I believe this is what you referring to. If I misunderstand, please correct me.
