using Newspaper with Ultimate Membership Pro WordPress Plugin?
I have bought your theme as it looks really good, but I’m wondering if I can use in conjunction with “Ultimate Membership Pro WordPress Plugin”?
Regards,
javier
The only tested and recommended plugins to use with our theme are these ones:
Tested Plugins:
WP Super Cache- caching plugin
Contact form 7- used to make contact forms
bbPress- forum plugin
BuddyPress- social network plugin
Font Awesome 4 Menus- icon pack, supported in the theme menus
Jetpack- plugin with lots of features *it may slow down your site
WooCommerce- eCommerce solution
WordPress (Yoast) SEO- SEO plugin
Wp User Avatar- Change users avatars
Anything beyond this list is not tested and I cannot say for sure if it will work or not.
ok, thanks.
BTW, I get this error when trying to install “WP Super Cache- caching plugin”.
Incompatible plugin: This plugin is not supported on WordPress.com.
Do you know why it says it is incompatible?
Javier
sorry, never mind, I just had to download it.
Can I also ask you, in another demo you have an option to create/show and even pay for tours, but I’m using the travel guides demo, is there any option for me to get the tours develop into the one I’m using? how much would that cost?
Please provide more details to where you saw this functionality. Our demos only change styles, but do not change the functionality of the theme. Any option can be added on any at all demo.
