I am using the Post Loops 2 to bring in posts I have created, but it is bringing in all posts / categories, and I want to restrict to only 1 category.
However in the ‘Extra’ section it only offers me ‘Post Type’, and not a category selection.
How do I choose just one category?
You can use the Flex Block 1 and you can filter it to display the posts only from a category -> https://i.imgur.com/Nnt3zGX.png
The Posts Loops settings are divided into 5 tabs: General, Layout, Style, ADS and CSS. The Posts loop is a special block and doesn’t have filtering options.
Also, one of the options for pagination of the Posts Loop has the option for normal numbered and the flex blocks do not have this option.
The Posts Loop is automatically filtering the posts depending on the cloud template you set (for example on the category page there will be posted posts from that category).
