Using svg logo's and for background images
I have a vector logo, is there an easy way i can use this for scalability instead of a .png? where would i insert the code?
I would also like to use .svg backgrounds INSTEAD of using background images on blocks etc. is this possible through td composer. perhaps the css editor of an element?
thank you
WordPress by default does not allow the upload of svg files, there is a solution provided in this topic
https://forum.tagdiv.com/topic/svg-logo-not-visible/
So you could upload them and try to use them where you want.
