Using the Filter function to display posts containing two specific categories
Hello TagDiv,
I’m having a problem with the Filter option.
I need to show only the Posts that have two specific categories (both of them must be assigned the same Post) but not the Posts that have only one of them.
So, giving an example.
I have two categories: CAT1 and CAT2.
I want to show the posts with CAT1 AND CAT2 but not the ones with only CAT1 OR CAT2.
Is it possible to do?
P.S. Unluckly adding manually a tag/new category is out of discussion, because I would need to do this operation for many categories)
I’ll wait for a response and thank you in advance!
Unfortunately, our theme doesn’t have this option.
A solution is to have a third category and be added to the posts that contain those two categories.
If you really want this option, then you can contact our custom work team here: https://tagdiv.com/premium-customization-services/ and they will implement for you this feature in your theme if it is possible.
