Hello guy need some help,
i would like to have the Header image on Posts like this:
http://demo.tagdiv.com/newspaper_blog_travel/2015/12/15/td-post-lake-como-a-true-love-story/
At the moment it´s boxed: http://www.urban.dog/hundegesundheit/vorsorge/floehe-was-du-zum-flohbefall-beim-hund-wissen-solltest/
Can you help me? Also I would like to use the REv Slider on Fullwidth on my homepage header…
Thanks Sylvester
Hello Sylvester77,
This effect can be done using the ROW with Visual Composer and then you will have to add some settings, like this -> http://screencast.com/t/gXdnit7eb -> http://screencast.com/t/a1SgTedCi
Hope this helps!
