UTF-8 error causing problem for RSS / XML
I’m not sure what I’m doing wrong, but this type of error is new to me (been using WordPress for 7 years). Please forgive me if I’ve missed the answer somewhere else.
Visiting Juxtapunk.com/feed reveals the following error:
This page contains the following errors:
error on line 32 at column 31: Input is not proper UTF-8, indicate encoding !
Bytes: 0x1F 0x28 0x6F 0x6E
Below is a rendering of the page up to the first error.
The rendering of the page up to the first error reveals:
Juxtapunk http://juxtapunk.com Sun, 16 Aug 2015 00:39:43 +0000 en-US hourly 1 http://wordpress.org/?v=4.2.4 3 New T-Shirts from Ugmonk: Juggle, Ripple, Pinnacle http://juxtapunk.com/juggle-ripple-pinnacle/ http://juxtapunk.com/juggle-ripple-pinnacle/#comments Sun, 16 Aug 2015 00:39:43 +0000 http://juxtapunk.com/?p=491
Thanks for the support!
I usually check my feeds here:
http://feedvalidator.org/
https://validator.w3.org/feed/
try retyping the characters indicated in case they have some bizarre encoding embedded into the doc — edit using the text editor, not visual editor for that posts.
Thanks, that helped pinpoint the problem … still not clear what it was, but deleting the text cleared it up.
I had that happen couple of times from copy/pasting from MS Word, from something I’d pasted from a website … somehow some bizarre encoded character or space got munched and then when I pasted into the “visual editor” that encoding stuck, and broke our RSS feed same way. Anyway— the feed validator great resource for that kind of bizarre gremlin 🙂
