Variable Products – disable 'add to cart' button
Hello there!
I have a problem about woocommerce variable products.
Standard products works well but when I’m stocking variable products the “add to cart” button doesn’t work.
It wasn’t happening by the start, maybe after some updates but it’s not affecting by the plugins, as well.
Example page of a Variale Product: ” https://www.d-all.gr/product/%cf%80%ce%ac%cf%89-%ce%b4%ce%b7%ce%bc%ce%bf%cf%84%ce%b9%ce%ba%cf%8c-%cf%83%cf%84-%ce%b4%ce%b7%ce%bc%ce%bf%cf%84%ce%b9%ce%ba%ce%bf%cf%8d/”
İs it possible to find what’s wrong?
Best regards
I think the problem is related to a plugin that optimizes the website – https://i.imgur.com/Ug0jQa8.png please disable it and try again.
I hope this will help you!
Thank you so much for your answer.
I was thinking that I had disable all plugins for check if some of these affect the problem but as it seems not!
The problem was in this plugin..
thank you for your time!
