I have 3 different instances where the Related Articles are not appearing as expected. I’m guessing them all may be related.
1. On an Author archive page, the posts by the author used to appear as expected. Now they appear on only one Author page, not any other authors. Here’s where there are “no posts to display”: https://www.schoolnewsnetwork.org/author/ron-koehler/ . Here’s the one example where the posts display as expected: https://www.schoolnewsnetwork.org/author/janice-holst/
2. The “Related Article” feature is not appearing at the bottom of posts as expected. It used to appear, and now appears on no posts. In the Theme Panel at Post Settings > Related Article, the option is turned on. Here is a post where the “Related Article” feature is not appearing: https://www.schoolnewsnetwork.org/2018/12/04/students-flock-to-teaching-cadet-program-but-remain-unsure-about-education-careers/
3. More posts by Author are not appearing in a sidebar widget as expected. This is happening on all 8 instances of this widget. I am using TagDiv Block 11. It is being filtered by “all categories” and the Author number, which I have checked and is correct and unchanged from when it used to work. Here is an example (look in the right column under “Latest from Ron Kohler”): https://www.schoolnewsnetwork.org/2016/12/05/ron-koehler/
1. I do not quite understand what problem you are referring to, I check the links and all seams to look normal ( in this way look to me to https://www.screencast.com/t/iPzJVUo2xi9n ).
2. Please make sure that the relented articles is set, clear all cache and try to change the post templates.
3. Please make sure that you set well the settings for the filter by authors.
https://www.screencast.com/t/XWKCQk3D9bV
