Various Problem
Hello there,
I have a lot of roblem in my website http://www.monaco-baviera.it and I don’t know why.
1.
In homepage, when I try to go in the second page of CASTELLI DELLA BAVIERA, website go in a wrong page. I have disabled all plugin and at the end I have discovered that is the plug in YOAST. How is it possible?
2.
in this categories page, there is something wrong: http://www.monaco-baviera.it/cosa-vedere/chiese/. I want that this categories page must be like the others categories page but can’t work.
3.
How could I align to the left the “booking.com widget” with the others widget?
Regards and thanks a lot
Pietro R.
1. Please re-save your permalinks and see if it works. Also did you removed category base or use a plugin for permalinks? As on category page your permalink should look like this – http://screencast.com/t/BF7GQRaW0 – http://screencast.com/t/DiAPZWwKd
2. Please change the module to display articles on that category page: http://screencast.com/t/llrbIZG0
3. Try this custom css in Theme Panel > Custom Css: http://screencast.com/t/RynN7LMf
#flexi_searchbox {
margin:0 auto;
Hello Alin,
thanks for your answer.
I have followed your solutions but unfortunately without results.
I have resolved only number 3.
If I give you an account, could you resolve it for me?
Pietro R.
I have checked your site and found that you have also managed to change the module for this category – http://www.monaco-baviera.it/cosa-vedere/chiese/ If you don’t want Slider for this specific category you can disable it(for each category) – http://screencast.com/t/HPq11xGMiT
Please provide more details about your permalink settings(if you use a custom structure) that you use and try also with a default permalink and see if you still have this issue with pagination. Let me know how it goes!
