Hi there
I would liked to reduce vertical space between 2 posts in a module block9, which is Module 8 in Theme Fonts, I don’t understand how to do it ? Is there a possibility to add a custom class to a block ?
Only PostDate is visible in that block and it seems it keep space for others options (author, comment …)
my working web site : http://plamotte.fr/Mondafrique/
You can do this via custom css in Theme Panel > Custom Css to reduce the margin and padding for module 8 – http://screencast.com/t/74JEKl0gn7Vr
.home .td_block_9 .td_module_8 {
margin-bottom: 10px;
padding-bottom: 10px;
This css is applying only for your homepage, if you want to have that css for all pages where you use block 9 just remove .home class.
