Very boring issue in tagDiv Composer – problem of image proportions
— sorry for my english —
Hi, I need your help:
i have create this page (http://www.assistentesocialeconte.it/ribellarsi-la-rubrica-del-mediatore/) using the plugin “WPBakery Page Builder” and I have set 2 columns, in the left column i have insert an image so that its width is equal to that of the column.
in this picture you can see how I set up the page:
how i have set the page
and in this other image you can see how I set up the properties of the block that contains the image:
how i have set the image block
  • Why the image continues to be rendered incorrectly by displaying its maximum height?
  • Moreover, the “On click action” property is not executed and so, clicking on the image, nothing happens (it should go to the home page of the site)
PS: I tried to disable the plugin tagDiv Composer and the image is displayed correctly. (but I can not leave the plugin disabled because I need it for other things).
Thanks for your help!
  • This topic was modified 8 years by managerfx.
Please notice that we do not recommend to use both page builder at the same time because could appear some conflicts. We recommend using only TD Composer as page builder and disable the Visual Composer. Try the Single Image elements from our page builder, like this -> https://www.screencast.com/t/uGVeFxIsW2gB
Hi Catalin, thanks for your answare, I have follow your suggest and I have disable the Visual Composer.
However in this way I have lost same controller like for example the Tab Constroller
example of tab controller
In TD Composer there is something like that?
Thanks again!
Hello managerfx,
I’m sorry but the Tabs element does not exist in our page builder, sorry!
